1 - 8 of 8 Posts
Can someone tell me what & where this wire go's. I remember it was from the Trunk harness in my 68 convertible but after 9 years I'm a little bit fuzzy on the exact location.
Thanks, Tony
I may be wrong but memory says its for a trunk light.
Reactions: hydro462
in 69, the orange wire in the harness running back to taillights was power to the dome light, but you wont have that in a convertible I guess you could use it for trunk light if you have one of them. there was also a white wire that went to the dome light from that same harness.
the tan wire with the boot connection i believe is for the fuel tank sending unit.
Jim
Ok Trunk Light sounds good. Was there a push button switch like the one on the A pillar for the courtesy lights ?
Trunk lamps in these cars contain a mercury tilt switch in the assembly itself, there is no button.
1 - 8 of 8 Posts
