1 - 2 of 2 Posts
If you are going to put the D-96 optional stripe on you 68, your going to need the assembly manual page and the stripe kit from one of the venders to do it correctly. The stripe was taped, not painted. The dimensions are not constant. They vary depending on which panel they're on. If you are going to paint it on, you will still need the assembly man to get all the dimensions correct..
1 - 2 of 2 Posts
