Chevelles from 1964 - '72 have a small strip of paper, about 2 inches wideby 8 inches long or a square about 5 inches by 7 inches that is usuallyburied in the cotton stuffing of the rear seat, in the backrestof the front seat, or drivers bucket. If you are lucky enoughto find this, (the mice usually have other plans for it) thenphotocopy it immediately and put it back, the last thing you wantis to lose it after having it right under your butt for so long.If you make a copy and replace it you are ensuring that the nextguy (hey, we all know you plan on keeping this one forever!)can enjoy the thrill of "finding" this original documentation.Build sheets usually confirm what the Cowl tag willtell you, but in more depth.
Build sheets consist of the following information:
The model number, starts with 1 followed by 4 or more numbers.eg 13867.
A pair of letters will designate the paint code.
A three number series will designate the interior.
A series of one letter and two numbers indicates the factoryinstalled options.
If you can find your build sheet, then just look up the codesin the available lists and you'll know for sure what your caroriginally came with. No arguments.
These numbers decode as follows:
* submitted via email... thanks!
Jump to the following areas:B / D / K / N / P / U / Z
Note: The Canadian Classic Chevelles and Beaumonts offer a year by year breakdown of this OPTION LIST
Or start scrolling!
AG7 6 way Power Seat
AK1 Custom Deluxe Seat Belts
AL5 Deluxe Rear Center Seat Belt '67.
AN7 Strato-Bucket Seats, Swing out!
Al3 Power Door Locks
Al6 Power Tailgate Release
AO1 Soft Ray Tinted Glass, all windows.
AO2 Tinted Glass, windshield only.
AQ2 Electric Seat Back Lock Release, '71
AQ5 Electric Seat Back Lock Release, '70
AS1 Shoulder Harness, '67+
*AS1 STD FRT HRN (1970 Malibu)
AS4 Deluxe Rear Seat Shoulder Harness, '68+
AS5 Standar Rear Seat Shoulder Harness, '68+
AT8 Reclining Passenger Seat
AU1 Electric Door Locks, '70+
AU3 Power Door Locks
*AV3 3 Point Seat Belts (from 1972 Build sheet)
A20 Custom seat belts, '64
A20 Swing Out rear windows, Laguna
A31 Power Windows
A33 Power Tailgate Window
A39 Custom Deluxe front and rear Seat Belts, 66+
A37 Seat Belt Equipment, '64 only.
A41 Power Front Seat, 4-way
A42 Power Seat, 6 way
A41 Power Bucket Seat, 4 way.
A46 Power Drivers Bucket Seat, 66+
A47 Custom Deluxe Seat Belts.
A49 Custom Deluxe Seat Belts, w/retractors
A51 Front Bucket Seats, Astro
A52 Front Bench Seat
A62 Seat Belt Delete
A64 Custom Deluxe Rear Seat Belts, '65.
A65 Split Front Seat w/arm Rest
A66 Split Second Seat
A68 Standard Rear Center Seat Belt. '67.
A81 Head Rest, Bucket Seats
A82 Head Rest, Bench Seat
A85 Deluxe Shoulder Harness, '66 1/2 +
A90 Electric Trunk Opener
A93 Vacuum Door Locks, '69
BO1 Police Body Equipment, '64-65.
BO2 Taxi!! '64-65.
BW2 Deluxe Body Side Molding
BX4 Body Side Molding
BX8 Full Body moldings
BW1 *Delete tailgate ornamentation. This would delete the fake woodgrain (or black stripe) on the tailgate of a '70-'72 El Camino or GMC Sprint.
B2H Interim Equipment Change, Huh?
B2M No power steering.
*B22 Door trim pad emblem " SS "
B37 Colored floor mats
*B42 Luggage compartment mat (71?)
B44 Removable Load floor carpet
B55 Deluxe Front Seat Cushion, '67+
B70 Padded Dash '64-65.
*B75 lining lug compartment, '69
B80 Roof Drip molding
B81 *Delete tailgate molding. This would delete the horizontal trim strips on the tailgate of a '70-'72 El Camino or GMC Sprint.
LS5 454-365hp in '71...270hp in '72 - LS5 (was also 360 HP in '70).
LS6 454-450hp, '70
LT4 400-180hp
L65 350-145 2 barrel
L90 Six cylinder
MO1 Heavy Duty Clutch
MC1 Heavy Duty 3 spd Transmission
M10 Overdrive
M11 Floor Shift Transmission, '71+
M13 Heavy Duty Transmission
M20 4 spd standard transmission.
M21 4 spd close ratio
M22 4 spd, Heavy Duty
M35 Powerglide automatic, 2 speed.
M38 Turbo 350 automatic
M40 Turbo 400 automatic
M55 Transmission Cooler
NA9 Evaporative Emission Controls
NB2 Refers to:: EXH EMISSION (from 72)
NC8 Chambered Exhaust System
NK1 Cushioned Steering Wheel
NK2 Custom Steering Wheel, '71+
NK4 Sport Steering Wheel, '71+
N10 Dual Exhaust
N30 Deluxe Steering Wheel, '67+
N31 Custom Steering wheel
N33 Tilt steering
N34 Wood grained steering wheel
N40 Power Steering
N41 Power steering
N65 Space saving spare
N95 Wire Wheel covers
N96 Simulated Magn. Hubcaps
P19 Spare tire lock
P58 7-14.4 Whitewalls
P61 7.75-14 W/W
P62 7.75-14.4 W/W
P67 6.95-14 w/w
P77 8.25-14 w/w
P90 G70-15 White Stripe
P91 G70-15 Red Stripe
PA2 Simulated Wire Wheels, 2nd style, '68+
PA3 Deluxe Wheel covers
PE1 Turbine 1 wheels
PE2 Turbine 2 wheels
PK2 G78-14 w/w
PK4 G70-14 Red Stripe
PL3 E78-14 White Stripe
PL4 F70-14 F70-14 White Letter
PL5 F70-14 White Letters
PM6 G78-14 White Stripe
PM7 F60-15 White letters, SS models. (also on Sprint SP models).
PN5 7.75-14 8 ply tires
PO1 Wheel Trim Cover
PO2 Simulated Wire Wheels, 14"
PO6 Wheel Trim Rings
PQ7 8.25-14 w/w tires
PR3 8.25-14 8 ply w/w
PU8 G78-15 White Stripe
* PL2 E78X14 B/WALL
PW7 F70-14 White Stripe
PW8 F70-14 Red Stripe Tires
* PX5 F78X14 Black Wall Belted (70)
PX6 F78-14 w/w
PX8 G70-14 w/w
PX9 G70-14 Dual White Stripes
PY4 F70-14 w/w
PY5 F70-14 Red Stripe
PY7 G70-14 Red Stripe
QDR gr78-15 radial whitewalls
QEH E78-14 bias White Stripe
QEL HR78-15 Radial white stripe
QGF G70-14 Bias White stripe
QGK G78-14
QGL G78-14 bias white stripe
QHE H78-14 Bias
QHF H78-14 Bias white stripe
QQZ HR70-15 radial whitewall
QRM GR70-15 radial whitewall
QRN GR70-15 Radials
QRV HR70-15 Radials
QRZ GR70-15 Radial White Letter
TO7 7.75-14 W/W tires
T15 7.75-15 8 Ply tires
T58 Rear wheel skirts, wow. (Monte Carlo)
T60 Heavy Duty Battery
UA1 Heavy Duty Battery
UM1 AM radio with tape, '70+
UM2 AM/FM with tape
UO3 Low note horn, D.
UO5 Dual horns
*UO8 horn, dual electric (1972 Monte Carlo)
* UF1= Mirror Lamp (available in '70-'72).
UF7 Econominder Gauge package
U14 Instrumentation package
U15 Speed Warning Indicator, '67+
U16 Tachometer
*U18 Export Speedometer
U25 Trunk Light
U26 Underhood Light
U27 Glove box Light
U28 Ash Tray Light
U29 Instrument Panel Courtesy Lighting
U35 Clock
U46 Lamp Monitoring Equipment
U57 8 Track Tape Player
U58 AM/FM
U60 Manual radio
U63 Basic old AM radio
U69 AM/FM radio with buttons.
U73 Manual Rear Antenna
U75 Power Rear Antenna
U76 Antenna in windshield
U79 Stereo Equipment
U80 Rear Speaker
VE5 Deluxe bumper strips
VO1 Heavy Duty Radiator
VO2 Heavy Duty Radiator, '64
V30 Bumper Guards. Full set. -Front only bumper guards on El Camino / GMC Sprint. (El Camino / GMC Sprint never came with rear bumper guards).
V31 Front Bumper Guards, '64-70
V32 Rear Bumper Guards, '64-70
*V48 Engine Coolant(Antifreeze)
V55 Roof Rack
V74 Hazard Warning Equipment, '66.
V75 Traction Dispenser set-up.
* W84 Additional fuel for delivery
YB5 General Processing Option (beats me?)
YD1 Trailoring Axle
YE7 *Special Performance "SP" package ('71-'72 GMC Sprint only). This was the GMC equivalent to the Chevrolet Z15 "SS" package.
YF3 The Heavy Chevy Package
YF5 Emission Tested
*YF8 Black Stripes (from 72 build sheet)
YJ9 Exterior dressemup package
ZO1 Comfort and Convenience Group, '64-65.
ZO2 Pushbutton Radio and extra speaker, '64.
ZO4 Heavy Duty Chassis, '64-65.
ZO8 Body Molding/Trim
ZJ7 Ralley Wheels
ZJ9 Auxiliary lighting group
ZJ6 Special Sport Sedan, '68+
ZJ7 Steering Wheel Deluxe Trim
ZJ9 Auxiliary Lighting Group
ZK3 Deluxe Seat Belts, and Front Shoulder Harness, '68+
ZK5 Concours Sedan, '68
*ZK6, 7 Concours Sport Coupe, '68
*ZK8 - Refers to Tire Pressure Label, '70
*ZR8 - Alternate Stripe Colour (SS)
* ZKQ - tire pressure sticker
ZL2 Special Hood, Cowl Induction, '70+
* ZL3 SS 396 CONVER--
ZO9 Performance Rear Axle, '70+
ZP2 *Trim & color override. This was for cars that had an exterior/interior color or trim combination that was not normally available. This code is listed on the build sheet for a '71 GMC Sprint that was "Classic Copper" with a "Dark Saddle" interior - a color combination not normally available.
ZR3 Refers to: = Off road package 454(LS7 & LT2) 69*
*Z02 refers to: **SPEC PAINT** (from 72 tag)
*ZP3 Special Paint
ZP5 *Appearance guard group.
*ZQ2 Convenience Group
*ZQ7---Canadian Warranty Booklet&Misc Literature
ZW4 *Std Trans 3spd (70)
*ZX1 EXP PROCED #1 (says charged to G.M. OVERSEAS DISTRIBUTION in lower left corner)
Z13 Comfort and Convenience Group, second style, '64-65.
Z14* Refers to: = A/C BODY CONV (info from 72 Chevelle)
Z15 SS equipment. (454 in '70 '71) | SS EQP PKG (72)
