1 - 8 of 8 Posts
I'm going to hook up a internal regulated one wire Alt. My questions is, what do I need to do with the existing External Voltage Regulator? Do I just unplug it or do I need to connect the wires somewhere else?
You NEED to do nothing. The gen. light will stay on though, I think there are people here that can help you make it go off though. I don't think it is possible to make the gen. light work properly with the one wire alternator. I have a one wire, and the factory generator harness is just unplugged and hanging around looking like it wants to be plugged into something.
chris
[This message has been edited by bulb122 (edited 03-10-2002).]
Discussion Starter #3
thanks, I don't have my Gen light connected currently, I just wasn't sure what to do with the existing External voltage regulator harness
Chris, I have a one wire that I am going to use. I have heard that at lower RPM the car runs on the battery. So in stop and go traffic you are draining the battery.
Have you found this to be true?
Larry
TC # 1000
66 Malibu - under transformation
My 66 Chevelle
Larry, I don't really know if technically this is correct about running off the battery at low rpms. I DO notice that after starting the car, the electric fuel pump is running slow, until I goose it once past 1500 rpm or so, then it runs at normal speed. Also, the headlights are slightly dimmer at IDLE, but they brighten up immediately off idle. I have never had a problem draining the battery, and that includes stop and go traffic at night with lights, elec. fuel pump, and electric fans. I can only tell you what I know from my experiences, I hope those of you who actually know how this works will chime in!
chris
You know, now that you asked, I don't know what amp rating it is. When I bought the car it had a chrome (yuk) one wire. That one fell apart (don't ask) and I went to the local NAPA. They rebuild alternators right there, and he put together a non-chrome one wire one for me. (and refused the chrome one as a core!!) I don't believe it is an especially high output one. What is a sort of rough standard from the 70's - 60A? If there is any way to check, let me know. I've been searching for a reason to go to the garage and NOT spend money!
chris
I have a one wire.
When you first start the car, rev it over 1500 to kick in the alt. After that, it's ok unless the rpm falls below 650 or 700rpm.
I like mine.
Dave
1 - 8 of 8 Posts
