This 67 chevelle has power steering. When you drive it the wheel doesn't return to what I would call neutral. Any suggestions. The gear box has some slop in it. Thanks again Slime
Yo Slime.
Betca if you pull the horn button and steering wheel nut. the Line thats an the steering wheel is not lined up to the Dot or
scrib line on top of the steering colunm
shaft. If it is You must look farther.
But if everything looks OK I would just POP
the steering wheel and reinstall it right.
Later
Good luck
Wayne
ACES TC
Slime, Take it to a reliable front end shop and tell them your problem and ask them to inspect the front end and align it.
Leo Paugh
Maryland Chevelle Club #017
Those who do the world's real work don't usually wear ties.
Alignment will normally fix this - if they know it is wrong to start with.
If not, there are further problems.
Gotta have a Chevy !In Durham N.C.
Why is there never enough time or money to do it right the first time, but ALWAYS enough to do it over?
Make it look the way you like it, forget what the other guys say!
