my 1st post i hope it is in the right forum. i have not messed with cars for 25 years or more so i am a Bit rusty. i have a 72 big block car. i want to go with a 454 stroker with a tunnel ram. the rear end gears are 411's and i can change that if needed. i want to use a 6 speed manul so i can play at low end and still go on short trips without running a high rpm, what traney would be best for me and fairly easy to set up. thanks for any info
Not sure why you omitted 5 Speed O/D units. Richmond Gear makes an OD unit but the low gear is LOW @ 3.04. That will make your 4.11's "look" pretty deep in first gear. Richmond is currently in the process of selling off their gear division so getting a trans is a bit tough now because of issues with the sale. The trans is very very close to a bolt in with minor floor dimples required and a bit of easy surgery to the crossmember. Might be easier install than the 6 speed T-56 but the rear end issue (overall multiplication in low gear) still needs to be addressed in your mind before you pull the trigger.
4.11's are just too low or anything under 2.20 in first. People are tearing 3.08 and 2.73 rears apart left and right when in reality ratios like that are the a resource for those guys without O/D who don't want to hear the engine beating its brains out on the highway.
IMHO the 3.nn low that is in the Richmond or the 2.89 in the TKO mentioned below are just too steep for the 4.11. The OD in eather the RIchmond or the TKO works in high gear (with 4.11's) on the highway. Certainly it works. The issues of the first gear overerall multiplication are however HUGE.
Simple math here using the Muncie 2.20 as a bench mark and the TKO with your 4.11's.
2.89 x 4.11 = 11.89 (TKO with your 4.11's)
Close ratios Muncie with popular ratios from back in the day
2.20 x 4.11 = 9.02
2.20 x 4.56 = 10.32
2.20 x 4.88 = 10.73
2.20 x 5.13 = 11.28
As you can see 11.89 is > 11.28 so you would be looking at an overall ratio DEEPER than 5.13 would yield with a 2.20 Muncie. I don't know about you but that is unthinkable for me. As I do the numbers that 4.11 of yours is a dinosaur with almost any of the O/D transmissions that are out there now. It is up to you but that is my $.02.
