1 - 12 of 12 Posts
I know from previous posts that some Old's 12 bolts are really just 10 bolt gears in the 12 bolt housing? (Or something like that)
Is anyone able to tell by these photos if this is a real 12 bolt that would work in a 67 Chevelle? (It's from a 70 Cutlass)
It has 2.56 gears. Here is the craigslist add
If it's 10 bolt gears though, I will pass. I thought maybe someone would be able to tell something from the photos
· Administrator
Just looking at the Richmond site to see if that's correct.
Seems that the P/N's for the "O" axle and the "8.5" axle are different.
http://www.richmondgear.com/01gm.html
Doesn't appear that there interchangeable.
Wally or Tom ,anything ?
I'm fairly sure all the BOP 12 bolts have the smooth cover pictured above........unlike the chevy 12 bolt's V groove.
Not what you want.
An Olds 10 bolt is stronger than a Chevy 10 bolt. They stuck them behind 455 torque monsters! I had one in a '66 Cutlass with a 2nd design L88 with 4.33 gears and it held up with L60 Polyglas Goodyears.
Does it have bolt-on axle bearing retainers like the Ford 9"??
Some GM rear's do and I always forget which??
pdq67
If it's a BOP rear, it's bolt in bearings instead of c-clips.
1 - 12 of 12 Posts
