1 - 13 of 13 Posts
All new harness's front to rear,, turn on right turn signal,,, it blinks,, but so do all 4 side markers , and dash lites,,, 69 Chevelle BB 4 spd tach and gauge car,,, any ideas ????
possibly missed one of the grounds
or a problem in a light socket
don't know how this makes you stupid though
Stumped,,, not Stupid,,, well maybe alitte a both
Im gunna retrace everything,,, have put in a dozen harness's never had this happen before
Most likely you haven't done anything wrong. Maybe made things too pretty.
The 69 outside lamps get ground through the bumper. Sometimes that isn't making a connection.
Get a piece of wire. Touch one end to the light bulb base when it's installed. Touch the other side to a good sheet metal ground or to the battery (-) post. You probably need to use the battery post 'cause you have a shiney car.
Turn on the signals and see if this changes how it behaves. The idea here is to put ground right to the light bulb if that makes sense.
Guessing it's one or both front marker lamps not grounding to the bumper or the bumper isn't grounding to the frame.
Originally posted by Herb:
Nice.
See, Hank would have tried to bury it. :D
Glad he cleared that up. I had to drive a ground rod here before, what a PITA, we have lots of rocks. That little roach clip will make it a lot easier.
1 - 13 of 13 Posts
