That is a spring with a higher rate than the spring that is already installed in the pump. You can install the spare spring, if you want more oil pressure, but I recommend that you install the pump as-is. Your pump should have had an instruction sheet that explains the extra spring and how to install it. You know, that piece of paper that really didn't look very interesting - and probably just some guy's opinion anyway (LOL).
