I recently bought a Sport Comp electrical oil pressure gauge from Auto Meter and the sending unit is absolutely HUGE compared to a stock unit. I was going to 'T' a fitting into the existing sender hole, but I don't think said fitting will hold up over time. Is there another hole tapped somewhere I could install the second sender unit? If not, any other suggestions on how to hook it up? This is on a 454 BBC going into a 71 SS so I'm also thinking clearance will be a little tight at the back of the block.
Thanks for this and all the other great info you guys provide.
Bill C.
Bill C.
