I have a 67 el camino with a 4-speed and headers I want to hook up a oil pressure gauge it seems impossible to get to the oil pressure fitting without removing the inner fender and possibly the z bar is there a better way or is that it?
I can't speak for the inner fender but pulling the "Z"Bar is sure no big deal. Frankly I can't imagine that its necessary to pull the inner fender. I'd remove the header long before I'd take the inner fender out. JMHO
Then if things were still too tight I'd remove the drivers side motor mount thru bolt and raise the engine a bit on the drivers side for better sending unit access.
course I am accustomed to working on SBC's. Haven't had a BBC since 1970.
