I have a Goodwrench 350 in my truck currently, well some jack*** screwed up the threads on the oil pan on it before I bought the truck :angry: (sad part engine was only a year old when i got the truck). Anyway the pan needs to come off for a reseal and welding in a drain plug nut. I would like to use a one piece steel shim gasket but as anyone with a replacement 350 from GM knows it has the ability to put the dipstick on both sides of the engine making the gasket and oil pan unique to the goodwrench 350. Does anyone out there know if anyone makes a gasket for the Goddwrench 350?
The joker who stripped it already did that and it leaks :angry:. Besides it leaks at the pan gasket too, so if i have to pull the pan to weld in a repair drain anyway I will replace the 3 pieces gasket with the 1 piece steel shim style.
