Quik,
Jack it up high in the front and block it,take the flywheel cover off, clean the area with a spray brake cleaner. Buy a couple cans so you'll have plenty. Get a good flashlight and look under there with the engine running at a fast idle. It might take a while but eventually you'll see the oil coming out. After you've been under there a while you'll be able to make out the diff between the the crank, the main cap and the pan.
It's well known to be easier to pull the engine out to pull the pan off, don't even try it in the car.
Tom
