The Speedway Motors website says that the pan you have is a guaranteed fit. Pictures of the underside show that the pan has the required clearance reliefs for inner tie rod clearance. Have you tried it?
Hey zookpr thanks for the reply. I’m sorry for the delay in response. No, I have not tried it for fitment. I wanted to be sure before I put it on the new engine. Thank you very much. I never thought to check fitment through speedway. I always overthink things lol. Thanks again. Will let you know how it turns out when I get it together.The Speedway Motors website says that the pan you have is a guaranteed fit. Pictures of the underside show that the pan has the required clearance reliefs for inner tie rod clearance. Have you tried it?
