Either the pcv valve is toast, the wrong one, or is not pulling enough vacuum. The other alternative is the rings are worn. Sometimes it will happen when you run 'em hard for awhile, clean it up, check the pcv system and see what happens.
If the filter is in the air cleaner housing then also make sure there is no restriction in the air intake (snorkel - if you have the warm air pipe, that the valve is not sticking).
