70 Chevelle, 489 BB, Jerico DR4
70 tach dash and I'm also running an aftermarket temp guage that's plumbed to my intake manifold. The factory temp sender won't fit in my Dart heads that have a smaller 3/8 pipe,I believe.
Is ther another sender I can use that is the next size thread size down from the OE sender?
Thanks!
John I don't think the sensor would fit inside the reducer. The only option I have is to find a different sensor or move it to the manifold which I don't want to do :(
Looks like Dart drilled those heads for the aftermarket guages that come standard 3/8 I believe.
Don't see why not as far as mechanically tying things together. A 3/8 male into the head and 1/2 NPT female to screw the sender into. Sender may try to bottom out but I don't think it will. The only question I had was would there be a noticeable difference in temperature reading? I wouldn't think so. I'd try to get a brass fitting.
Not sure how significant the change would be but temp senders are designed to be in the cooling water flow path. Using a reducer would move the thermocouple out of the water jacket.
I decided to just run my aftermarket in the intake and skip the head for now. I guess I could reverse it and run both guages if I modify my harness a bit.
