I've scanned this site and can't find anywhere, the torque specs on the replacement Ball joint nuts for a 1967 Chevelle "I'm talking the 4 nuts that hold the ball joint to the A Arm". The assembly manual doesn't cover it because they were riveted on, the instructions say to refer to service manual
Can someone tell me how much to tighten these down. I went to 30 ft. lbs., hope that's enough.
Also, The Assembly Manual doesn't talk about torque specs on the Upper control Arm Bushings, just the shaft to the frame, not the nuts on the end of the shaft... seems a little strange:sad: does anyone know the torque specs and if this needs to be done with the car on the ground first?
Thanks,
Clay
Thanks,
Clay
