does the nuetral safety switch play a role in power t the coil? as in if it were burnt id have no power to my coil wire/?
Discussion Starter #3
so then the purple wire coming from the switch that traces into the ignition switch on the colum then goes into the fuse block and comes out and runs directly to my coil dosent play a part in the no power at the coil wire problem?
Your purple wire coming out of the fuse block on the other side of the firewall should go to the "S" terminal on the starter, not the coil.
Dean was right, believe him.
Discussion Starter #5
yes he was my bumb arse didnt pay attention when fixing the broken connection and i plugged it into a slot that was empty thus resulting in no power . thanks guys for all the help and info.problem solved
