1 - 2 of 2 Posts
Heres my situation,
I currently have the whole dash out of my '67 and all the wires hooked up, including ignition. I have connected the small wire on the + battery cable to the wire on the firewall harness and the lights etc. should kick on, right? well, I turned the key and pulled the light switch out and nothing happens. I am going to be replacing the fuses though, any other things I could try???
thanks a bunch
wes
Sounds close, what about the negative side? The cable on the battery? What about the wire to the inside right fender? The headlights don't go through a fuse so that's not the place to look.
1 - 2 of 2 Posts
