Well I went home for the weekend and decided to do a little 100 mile cruise with my car and a friend with his 69 Chevelle. All of the little problems with my car have all added up to a big pain so I think I am going to take it all back apart.
Transmission was fine for the first 50 miles, but after that the manual valvebody Th400 decided that it didn't like staying in 2nd gear. I would shift it into 2nd gear, but it would only stay in 2nd for about 1-2 seconds and automatically shift itself into 3rd. Would randomly do this for the rest of the evening. Sometimes working, sometimes not. So this tranny will be coming out for the 8th time since 4 months ago.
Oil leaking out of the valve covers has left oil everywhere so I think that I am going to attempt a different valve cover with a breather as a last resort just to make sure that fixes the problem. Either way I think I am going to pull the motor and do a clean up.
Rearend is now leaking oil out of the back cover AND something seems to be bent on the driver side. I tried a different wheel and it still looks like it is wobbling so I am guessing that it is either a bent rearend housing or bent axle. (This could also be my vibration issue?)
I think I am going to take the motor/transmission/rear end out of the car and basically start over from 4 months ago. This time however I am going to do it right hopefully
. Here is a list of what I think I am going to try and have done over the summer.
Fix valve cover leak and clean motor
Fix transmission :angry:
Either fix the 12 bolt that is in there or put the stock 12 bolt back in.
New upper and lower control arms for the back
Aluminum Radiator and Electric fans
Roll cage
Anti Roll Bar
Move the battery to the trunk
Front springs
Get rid of all the rubber undercoating and paint it black
Swap stock gas tank for the tank with a sump that I have
Clean and repaint exhaust (Possibly add two resonators to the tailpipes to quiet it down a bit)
Any ideas about what the problem with the transmission could be? If I sat at a stop light for a few seconds it seemed to work for a short while afterward. Full throttle shifting seemed fine.
I checked the PCV valve as suggested and it is working just fine. So I don't think that is the problem with the valve cover leak. Oil pressure is normal so I don't think that is the problem. A valve cover with a breather will go on it this weekend to see if that works.
I have a small vibration that feels an awful lot like a bad u-joint. I changed both front and back u-joints however but that did not fix the problem. Could the rear end be that vibration? It gets much worse when coasting in neutral just like a u-joint going bad.
I just want to make sure that I know what to fix before I take everything apart again. I really don't want to put it together again and have the same problems. Just very frustrated with the car at this time.:sad:
On a good note I put a stock sway bar on it and it drove WAY better. Definitely an improvement!
Roll cage
Anti Roll Bar
Front springs
