I know this topic has be Beating to Death, so I will ask again.
I built a Friend a BBC 496 engine that is using Comp Cams 854 - 16 BBC hyd roller lifters. This engine while running at idle is Very Noisy, lifter's ticking, clattering. I used a dual valve spring that has 170 to 175 lbs on the seat with 420 to 440 lbs open pressure. Did I use to heavy of a spring. I was hoping by now the springs would have soften up a little and the noise would get a little quieter. When I assembled the motor, I used some lifter preload of .025 and used 15 x 40 Shell Rottella oil. This motor is on its second oil change with less than 500 miles on it. Should I change to a heavier oil like 20 - 50, will this help ?
Thanks for looking, Sorry to ask again,
Ron 92Camaro :beers:
