I have no turn signals the bulbs are new. There is no clicking sound comming from the car when I try to use them. Help please.
1970 Chevelle
305 (for now)th305
The best way to look at an import is in the rear view mirror
Both right and left are out? No lights coming on at all? Everything is off? The emergency flashers work ok?
If so:
Under the dash is the turn signal flasher can. Located somewhere between the steering column and the radio. It's on about 10 inches of wire and it hides. Colors to its connector are pink and purple. You should have 12 volts on the pink wire with the key on. Pink is the input and purple is the output. If you don't see 12 volts on the purple wire the can is bad. I tend to use the $3.00 replacements from some place like Pep Boys.
