Hi, I have a 67 with a 350 and a Pro-billet distributor and Blaster 2 Coil. I am getting no spark out of the coil. (I unplugged the coil wire to the distributor and tried to start with the wire close to a ground but there was no spark.) I am getting 12 volts from the positive and negative terminal of the coil (with ignition on and off). The started/solenoid appear to work ok. Any ideas? Thanks, Gary
Discussion Starter #2
I put a volt meter on all of the accessory fuses and they all registered 12 volts
May not be getting anything out of the magnetic pick-up circuit. Check out MSD's site. Under Tech Support there are troubleshooting guides. Those guides should give you an idea what's going on.
www.msdignition.com
