Heres my predicament... I'm not at home right now, but when i was i couldnt get my car started. I inserted a spark plug into a wire and had my dear old mom crank it. I tried lots of stuff, but didnt get any spark but once, and only once. Here is what I checked:
-There is power to the distributor
-the coil has .8 ohms of resistance from neg. to bat. terminals
-new dist., cept for coil...
-i recently hooked it up to full instead of ported vacuum
-new wires (msd, but ive had it running since i put the wires and dist. in)
-some black carbon crap on the metal points in the cap, where the rotor might contact it. i cleaned these off though. not carbon tracks.
well, this is all the info i know about it so you guys know as much as me now. i still have the module from my old dist., should i try that first? I'm not really in a hurry, i am going home this weekend and i just want to be prepared to fix this. How do i test the module? is there anything else that needs to be tested? well, if you have any tips, lemme have em! thanks guys1
Russ
Russ B.
'68 Chevelle 2dr Ht,
'69 8.2" Powertrax rear
'72 402ci Rat
'74 454 heads
All drums; they're not so bad...
...nice first car, huh?
well, it will be as soon as I spruce it up!
Russ
Russ B.
'72 402ci Rat
'74 454 heads
