Ok, message recieved. The fuse that is instantly blowing is the "tail lts" fuse, left side, 2nd from the bottom on the fuse block. The little stubby fuse at the very bottom of the block is hanging in there so far, but I'm not getting instrument lights. The switch I installed is an origional A/C Delco switch, checked by a reliable fellow whom restores dashes. I assume it to be good at this point. I'll start as you suggest, by pulling the plug to the rear of the car and see what happens. If it doesn't blow, I'll know there's a problem at the back side of the car. I may have two problems since the dash lights go through a different fuse (the little one). It doesn't blow, but the lights don't come on either. I have a test light and a nice volt/amp/ohm test box, so I'll hang in there with this. Can't take the Kerosene/match route, the damn car is just too nice. Even in the garage it looks like it's doing 90+ mph. If you have any other suggestions, lay em on me. Thanks ,Steve
