1 - 2 of 2 Posts
there is something outa wack in my clutch geometry. i'm installing an 11" dia. p.p. and the short throw out bearing. i have the 621 bellhousing. and i have to force the throw out bearing into the fork. the fork is gm 3892632 . then there is pressure on the bearing against the pressure plate ! i'm wondering if the piviot ball in the bell is too tall ? i took it out and it measures 1 9/16" top to bottom. is that what you guys have ? any ideas ?
Discussion Starter · #2 ·
nevermind , figured it out myself. the spring clip on back of fork wasn't letting ball fully sit in fork. bent it a bit, now i have play.
1 - 2 of 2 Posts
