O.K., The car is a straight-six 250, 2-door hardtop. It was running when it was noticed that the valve cover bolts were not tightened causing oil to leak. The car was turned off, and bolts tightened. On the attempt to re-start, the starter area began to smoke, the key was immediately turned off. Now, when the key is turned; nothing! No headlights, no dashlights, no solenoid click, no nothing!
What could be the problem(s)?
Could the fusable link in the starting system disable the current flow through the headlight or dash harness, or the entire car?
I don't have to replace the whole electric system, do I?
Thanks.
Thanks.
