I'm not getting any fuel to the carb. I originally thought it was the fuel pump. I put a new pump (Holley 12-454 - competition mechanical) on the car. It ran for about 10 minutes then it shut off. I can't imagine I have two bad pumps. The first was about 8 months old, but only had about 1k miles on it. I have a Harwood cell w/foam and a Mallory 140gph filter (10 micron). The only thing I can think of is the filter is clogged from the foam, but It is also new with only about 2k miles on it. Could it be blocked so bad that I don't get any (0) pressure? I removed the line out of the pump and nothing comes out. I have a separate line feeding a nitrous system with a Holley Blue pump. Can I hook that line to the mechanical pump to test it and have it pull through the Blue pump without turning on the pump? I want to make sure the mechanical pump works, so I have to leave the Blue pump turned off. If this works then I guess it is the filter. Also, it has new fuel lines (about 2k miles on them). Both lines have a regulator. Any other suggestions, or do you think it is the filter also?
[This message has been edited by Rob H (edited 02-01-99).]
