I went to top off the radiator today and was waiting for the temp to come up. The water level never dropped, so I went in to go to take it for a drive, and looked at the temp gauge. 240*. Ah! So my new problem is with the cooling. When I had the bypass hose on last week, it didn't happen. Could the lack of a bypass hose cause air to be in the system, so it doesn't reach the thermo? The way it looks is the bypsas hose shoots the water into the thermo housing. So I think I should go back to running the bypass? I need an answer ASAP because I need an inspection and need to be able to drive it there without the temp getting up. BTW, the thermostat is a 160*
Thanks a lot,
Chris
Thanks a lot,
Chris
