ive got a problem on my 70 daily driver. i just finished installing my custom dash a few months back when i realized i had no turn signals or hazards. now ive found out ive been driving without brake lights the entire time.
it all started when i think a wire got crossed and a faulty fuse didnt blow. smoke was billowing from the column until i pulled the battery cable. once things were sorted out and the ignition turned on, the flasher would not stop clicking. even though the flasher would click no lights would work.
i was trying to find the problem today, and i noticed that a wire going into or out of the column was completely fried. the wire is the one that attachs to one side of a connector with the other being the white wire coming from the brake light switch.
what is making the flasher click when just the ignition is turned on?
how do i access the wires in the top of the column(close to the wheel)?
i pulled the steering wheel but didnt go any further.
the only wires i cut with the new dash were the ignition, and accessory wires before and after the ignition switch and placed them on toggle switches.
any replies would be helpful... thanks, Tim
70 Chevelle My Ride
NEW Custom 70 Dash
70 Chevelle My Ride
NEW Custom 70 Dash
