Did you restore the car or did you add a gage dash in an original idiot light car? Either way you need the two wires for the ammeter hooked up. They go to the battery junction block and the horn relay.
Did you change out the temp gage sender from the idiot temp sender? You can see if the gage is workng by turning on the key. Remove the green wire from the sender. The gage should move. Ground the green gage wire. The gage should move.
http://www.chevelles.com/forum/ultimatebb.php?ubb=get_topic;f=22;t=003902
