looks great, what suspension on it?
It currently had a mixture of items under it that worked fairly well but I just recently decided to redo the front suspension and in the middle of pulling the car apart. I will have to add some recent pics of the work I am doing. I am going with a Speedtech's "Road Assault Suspension" with Coil Overs.looks great, what suspension on it?
From all my research there is more than 1 "Stock" width rear ends pending what brake and or year you compare. May be wrong but that's what I found. So with that said, I had the housing built (running a Fab9 9") from the specs I gave them when I fit the rear tires and wheels in the fenders and included the measurements for the Wilwood brakes I am running. If anything it may be a hair under but not much if I remember correctly. I would have to pull all my build notes.Are u running a stock width rear end?
Found what happening?Update on my front end suspension swap, I pulled the front end apart and found this happening. Any suggestions on why this would happen or see it before?
It's in the video above your post. I didn't see it right away neither.Found what happening?
No not 100% sure why they rubbed.It's in the video above your post. I didn't see it right away neither.
Thank you, the spoiler is from Anvil Auto off a 69 Camaro I believe the year was.Looks awesome been thinking about getting my bumpers and door handles powder coated as well. What brand air dam do you have?
That rear wheel & tire combo wouldn't come close to fitting a 68-72 with stock width rear and drum brakes, much less with the thicker hats of your Wilwood rotors.From all my research there is more than 1 "Stock" width rear ends pending what brake and or year you compare. May be wrong but that's what I found. So with that said, I had the housing built (running a Fab9 9") from the specs I gave them when I fit the rear tires and wheels in the fenders and included the measurements for the Wilwood brakes I am running. If anything it may be a hair under but not much if I remember correctly. I would have to pull all my build notes.
