I'm not sure were to go from hear. This problem started two days ago. I drive a nearly stock 70 Chevelle SS 396. When I accelerate hard off the line it pulls strong until 51-5200 rpm and then it loses it's power and back fires though the carburetor. When I let up on the gas it runs fine, better than fine it runs great. If I hit it hard again it pulls strong until 51-5200 rpm and then no power and back fires though the carburetor. It's weird but this car has never run as good as it has the past month. I took the car up to 5,300 very slowly with out the secondaries opening and no problem with power loss or back fire, it played hell with my nerves but I can't figure it out. The following is information that may help diagnose the problem and the particulars on the car.
Stock Q-Jet Rebuilt 1 year ago
Pretronix ignition module in original distributor It's been in about a year
1" spacer under Q-Jet It's been on about a month
Vacuum 20 Hg measured at the front of the Q-Jet for the timing advance & 22 Hg measured at the back of the intake were the power brake hose is attached
Fuel Pump about one year old
Timing: 15 initial 7 vacuum 43 total all in by 28-2900 rpm
Plugs: R44T nearly new
I've check the coil, plug wires and plugs for spark and it appears to be strong. I have good clean plugs and that's all I know. I'm at a total loss as to what the problem could be. Any help would be greatly appreciated from the newest official member of Team Chevelle.
Texas SS
1970 SS 396 350HP
Unrestored & Almost Perfect
Houston, Texas
Take a Look http://www.geocities.com/MotorCity/Street/6320
Texas SS
1970 SS 396 350HP
Houston, Texas
