1 - 2 of 2 Posts
hello my 1st post i have a 70 chevelle and pulled my 307 this weekend to install a 305 I'M haveing problems with the lining up of the mounts and trans to crossmember I did a search and now I'M very confused
I used the stock frame mounts from the 307 as well as the motor mounts from the 307 and with some work got them in but now the trans is off. ANY ADVICE PLEASE:confused:
Put a floor jack under the trans, being careful not to dent the pan, and lift the trans up. Don't use bolts to draw the engine and trans together or you could damage the front pump in the trans.
1 - 2 of 2 Posts
