I just installed a new cloyes true roller billet set and the cam gear is in towards the block .018 to .020 more then the crank gear.
I went ahead and installed the chain and cam button and timing cover anyway to see were it was exactly with all the shims same place as as they were when i removed it
after rotating full 320 I checked the endplay only in one direction towards the timing cover and get around .09
when I check both ways I get approx .028 from one end to the other end obviously this is from both gears being out approx .020 from each other.
what do I need to do????
