1 - 10 of 10 Posts
The original hood hinge rivets on my '69 SS 396 are worn. I've contact Willie @Hood Hinge Repair to have them rebuilt, but it appears he does not use factory correct rivets since he drills out the original rivets and slightly oversizes the hole. I hear his quality is excellent.
However, before I go that route and have the original rivets drilled-out and lost forever, I am consider this latest reproduction - seems much better than prior repro's. Anyone have experience with these:
Amazon.com: 69 Chevelle Chevy Fullsize Hood Hinges - LH & RH (Sold as a Pair): Automotive
or these @Ecklers for a few more bucks (I think they are the same as the above link).
Chevelle Hood Hinges, With Springs, 1969
Appreciate any feedback.
Thanks!
Re: Newe Repro Hood Hinges - Any feedback on these?
I can't comment on those repop's, but my original owner opted for repop's, and one day I went close the hood, and it failed on the way down. Buggered up the paint on the corners. I replaced with original GM hinges. 2X the price but what is your paint worth ?? If you already have GM hinges, send them to Willy. Next time I need hood/door hinges done they are going there...
Willie does great work. Most people would never realize that the rivets have been replaced. He has done 2 sets for me, and I am very happy with the quality and service I've received.
I had the same problem last summer. After some research I decided to have Willie rebuild my old ones. I can't take a change of having a hinge break and mess up my paint job. The rivets look the same to me.
If he makes the rivets bigger it will be mostly in the part between the hinges not seen to the eye.
SdD, I know you want to keep it as original as possible, but willie did amazing work on mine. Pretty sure mine were bent, I got them back and the hood closes perfect now.
:cool: Keep it to yourself (as I'm embarrassed to say that) the repops on my car are 10 years old and have been excellent.
I just got my hood on a couple days ago, after getting the hinges back from Willie. I couldn't be more pleased.
Crazy stuff...I've had dozens of cars with oem hood hinges with virtually all of them working just as they should. Over the years maybe 1 or 2 sets have been noticeably unstable. Possibly a regional thing.
I noticed the hinges were going bad on my 70. The rear of the hood would stay popped up a but (1/4 inch?) after closing it... I could push down on the hood, and it would sit fine...
I tried a set of repro (Goodmark?), paying for the better quality set...
I had trouble getting the hood to line up, turned out the slotted holes weren't in the right spot... After a frustrating hour-plus, I pulled the repros off and put the originals back on. NO "witness" holes, but within 5 minutes, the hood was aligned correctly...
I am planning on hood and door hinges with Willie for my '66... Someday...
1 - 10 of 10 Posts
