1 - 19 of 19 Posts
Just put a set of Headman headers on yesterday. After I drove it for about a hour to get them heated up, I rechecked the bolts. All the bolts moved about a 1/4 to a 1/2 inch. They are now all tight. Am I good to go or will they have to be checked again after driving some more. What do you exhaust guys think?
I check my bolts all the time , I have a few that just tend to back out ever so slightly, there are header bolt from ARP may want to give them a try.
there is a certain type of lock washer that's very small in circumference a tad bigger than the flange head on the header bolt they work great. there is a name for them but IDK what it is. you can buy them at an Industrial HDWE store i found out about these years ago at the HDWE by accident from another customer been using them ever since. Alex
hi
Serrated bolt heads that bind / bite into mating surface .Mr gasket allen head type
wire tie
lock plate
------lock washers
Mr gasket as above
Nord lock washers ,, these go real tight . Pack 10x washers on a bolt and lathe turn down / machine OD to size .
Ryan
Generally, you will have to snug them up a few times if you don't want them to leak down the road.
I just keep a wrench in the car and check them after driving for a while.
After a half dozen times they will get their set and stay after that usually.
I you run into problems with them loosening, lock washers like this have worked in the past.
Tacoma Screw Products | 3/8" External Tooth Lock Washers —Type 316 Stainless Steel, 100/PKG
Tacoma Screw! When I lived up there I loved that place. They always had all the odd ball automotive grade bolts to these cars.
I love Ft Lewis and we used to get to go there every year to do exercises with then US troops from all over that would converge on Ft Lewis!
Excellent guys and excellent base for Combat Engineer tactics. Since Covid it has been a no go sit. But now it may be back up for us this fall!
Ryan
Ya, I'm born and raised from the other side of the Narrows, and spent my Army time in West Germany
My grandfather was career air force, was stationed in Germany, and married my grandmother (she’s German). Then he retired from mcchord and stayed in the area. So I was able to spend lots of time with them while I was up there.
Ryan
Lots of good training areas. Jus don’t drive on the DZ or your unit will get a fine for disturbing the ground nesting butterflies!
Reactions: Capt Casey
Proform sells header bolts that have wedge washers on them. I bought a set for my car and they work great. I put them on and tightened them once or twice after running the car and the washers are the best for keeping the bolts tight.
That's cool.
Growing up on the peninsula was way different than the I-5 corridor. (We were considered hicks and ********.)
It was a sportsman's paradise back the in the day. (To many people know of the secret places, so not secret anymore)
The car seen was crazy in the 70's - early 80's. The cruising in Bremerton then would rival what was portrayed in American Graffiti.
Used to take an hour to make it through town down the main drag and it was only 6 blocks.
Ryan
That's cool.
Growing up on the peninsula was way different than the I-5 corridor. (We were considered hicks and ****.)
I like it up there. My parents have a few acres up in Sequim.
Reactions: LaVelle
1 - 19 of 19 Posts
