I ordered my 3.73s for the 66 today. So I am going to run those with the current set up and then see if that cures the launch bog and if I get an improvement in my quarter E.T. With my current set up what do you guys think would be my best next future change. Keeping in mind I am not looking for a super fast street car. I am looking to hopefully get the car into the 12s. 12.99 counts!!
My present setup for those who have not seen it posted. Motor is a 355 with Trick flow aluminum heads, 180cc intake port, 64cc chambers and 2.02/1.60 valves. Present springs have an installed pressure of 94-96lbs and an open pressure of 480 lift =288lbs. I give the spring info for cam upgrade limits. Cam now has a .454 @.050 lift and .216 @ .050 duration. 1.5 stock stamped rockers and hydraulic lifters. Pistons are dished at either 12 or 15.7 not sure as the info I got from summit lists both. Intake is a Edelbrock Performer and carb is a 1406 Edelbrock 600 cfm. Headers are Terminators by Flow Tech and I believe are 1 & 5/8 inch. 2 & 1/2 inch exhaust with H pipe. 4 Speed Manual T-10 Richmond Transmission.
