I need some suggestions, replaced the stock quadrajet 4bbl that needs a significant rebuild, (can't adjust idle air mixture)
installed the new carb, idle was extremely high, checked the timing, set it at 8* BTDC, idle was set right around 600 - 700 RPM, as soon as the truck is put into gear, idle drops , engine labors, not enough vacuum for the power brakes, runs great on the road.
No issues like this before.
Thanks, Mike
Thanks, Mike
