1 - 15 of 15 Posts
Took the camaro out with a new converter have my new best . These times are NA on pump gas 434 ci with a standard 23 deg head thru the mufflers on dot tires.
60 ft 1.401
1/8 6.382
1/8 mph 107.19
1/4 10.050
1/4 mph 133.55
:hurray::hurray::hurray:
Very nice :thumbsup:....what was the converter change?
How did it run before?
Discussion Starter · #4 · (Edited)
I went from a TCI super street fighter that ran at this track a best of 10.21 at 133.2 mph with a 1.48 60 ft to the PTC 8'' 5200 stall. The car runs faster at Bradenton and Gainesville tracks Plus tonight thay only preped the track once all night. That is the only time Iwas able to stick it to the track.
Hmmm...sounds like Moroso to me, we were there if indeed it was Moroso.
Is your car in black primer and did you ran in Super Pro?
We had our 78 Camaro (red) there for the first time with the new motor you might have seen it.
Excellent times !! and a small block at that, good job :thumbsup:
Discussion Starter · #11 · (Edited)
No I did not drive it there. I do not like changing tires at the track I am using the hossier dot radials not alot of tread. But I did win the true street 10 sec title in Bradeton with it if you are not familar with the rules this is the class where you drive the cars 30 miles then after a brief cool down you make three pass you are not alowed to pop the hood after the cruise only thing you can do is let air out of the tires.
Yes the car weights 3450 lbs. Thanks for the props every one I look over this sight it gives me more drive to go faster all the time.
Discussion Starter · #13 ·
Dart lil M block with a 4'' stroke 4.155 bore.
Custom dish pistons 11.25 comp.
6'' billet rods
Callies crank
Dart 227 heads
cutom grind cam dur @ .050 270 280 lift.670 .680 110lobe sep.
Keth Dorton Strip dominator intake
Pro Systems 1050 carb
Discussion Starter · #15 ·
Went back out to the track last night I tighten the front struts the car left the line alot better no big wheel stands and or traction problems. had constant 1.41 60 ft times. I add 25lbs to the right rear to help out at the end of the night I pulled the weight out and went a 10.098 @133.66
1 - 15 of 15 Posts
