This is a 4 speed car and I am wrapping a FBO restoration. Is there supposed to be a micro-switch on the clutch pedal that keeps the car from starting unless it is pushed in? I have a pair of wires that I need to jump out to get the car to turn over. If so are they still available? I don't seem to have anything there.
71 SS Chevelle
468 cid
Muncie M-21 4 Speed
12 Bolt 4:11 Posi
Acting Like it Wasn't Me
On my 70, theres a slider switch that connects to the clutch pedal bracket and the slide rod connects to a hole in the clutch pedal beam. 2 wires attach to the side of the switch. The switch and slide rod looks like white nylon.
Ed C.
70SS 396/350 4speed
70 LS6 4speed under resto.
00 C5 6speed
Not sure where to find this equipment, but 1969 was the first model year (I belive) for the "clutch pedal saftey switch". Might have luck in a junk-yard if you can't find a supplier.
