neutral safety switch
829 2
Have '67 Post car. Think it might have been original stick shift. Is that why I can't find a neutral safety switch in harness. Putting in automatic on floor and would like to install switch. Anyone have electrical schematic they can post or email to me?
[email protected]
Thanx,
Ken
Yes in 67, manual trans cars didn't have a neutral safety switch. The purple/white start wire runs directly from the ignition switch to the bulkhead to the start solenoid. If you want to add a NSS you will need to cut and splice. If you are wanting to add this to a floor shifter I recommend you use a relay. Run the relay control wiring through the floor shifter switch.
