On a '68 small block, where does the negative cable attach to the engine? Could not find an illustration in the assembly manual.
Discussion Starter · #2 ·
I'm sure that I'm not the only one with a small block. Seriously, I would like to install mine to the proper location. thanks
I don't have a 68 assembly manual, 67 has a special bolt for the right upper water pump. It's a double bolt, threads in both directions from the head, for the - battery cable. I think 68 is the same.
The ground cable information is in the assembly manual, it will be in the first several pages of UPC 12.
Thank you very much.I'll locate the correct stud. There is one like you mentioned on the other side of the water pump that attaches the alternator bracket.
