1 - 2 of 2 Posts
The retainers usualy have two holes and an arm with a clip that goes on the shaft of the rod. You take round end of the clip and straddle the tab with the hole in it, push the little bent elbow of the rod through all three holes (clip, tab, & clip) and then rotate the clip down and snap it on the straight part of the shaft. You'll probably get it backwards the first time but you'll figure it out. Or go look for the same type of clip on another rod in the door and study it. Carbs have them too.
1 - 2 of 2 Posts
