1 - 2 of 2 Posts
Hey all,
As the title says - when I turn parking lights or full lights on, my temp and fuel gauge slowly peg themselves to the right.
I pulled and checked the gauge pod/printed circuit, it looks OK. Nothing is crossed, worn, broken, etc. on the circuit. Gauges work perfectly UNTIL I turn the lights on.
Ground strap is connected off the headlight switch. There are no other grounds from the gauge pod to the car anywhere.
I need to know where to start looking and how to diagnose this - any help is much appreciated!
Discussion Starter · #2 ·
Problem solved -
Added a ground wire to the body from each "section" of the cluster (except at the light switch, which already had one) - works perfectly now! And, my dash lights got brighter, too....
1 - 2 of 2 Posts
