Hey All,
I've about reached the end of my shadetree ability. I would appreciate some thoughts.
I'm running a Mallory Unilite distributor (electronic ignition---the one with the LED trigger). I'm also running a Mallory ProMaster Coil (PN 29440). Carb is a 600 CFM Eddie.
Drove the 350 crate engine into the shop a couple of weeks ago after a nice run around town. It ran like a champ; idle great....Shut down per normal.
After 2 weeks of not running I went out and started it up. Ran as normal for about 30 seconds...then died out by dropping idle speed from 750-800 RPM to 0 RPM in a little less than 10 seconds. Sort of reminded me of when you crank on a cold morning and the choke isn't working properly and the engine slowly winds down but in this case choke is working.
Would NOT start back up. I waited a couple of days until I had some time to do some checks. Again, after sitting 2 days, it started up and ran for around 30 seconds and then wimped out again....same pattern.
My first thought was fuel starvation.....pulled the breather and hit the carb linkage and gas jetted into the primaries.... Check; fuel present.
Next I checked the Mallory distributor....Measurements suggested a possible weak spark so I ordered a new Mallory Unilite Control Module PN 605 (the electronic 'eye' module that mounts inside the distributor). Also ordered new distributor cap and rotor...
Got the parts in...installed and got a good test on the Unilite suggesting a strong spark.
Hit the starter and, you guessed it, ran for 30 seconds and gradually died out.
Back to the fuel system I went and swapped out the fuel filter.
Hit the starter and grind, grind, grind over she turns.....but no start this time. New fuel filter is full of gas so apparently fuel pump is working....
It's odd....ran great the last time out then the 30 second run then die.... That would seem to indicate it's not the carb so what else is left????
Anybody have any thoughts? I'd surely appreciate some speculation and things to try that I might have overlooked....
