So I purchased the car with a 383 in it with about 1000 miles on the motor.
I had an oil leak on the back after changing the oil pan while it was in the car and decided to pull the motor and fix it while I was changing out to a higher stall torque converter. And I was getting oil out of the right side exhaust with a good even compression on all cylinders. So I wanted to investigate a bit.
I had partial records of the engine build but missing some of the details. So I started to tear down to a short block to measure everything.
Everything else looked good except for about 1/2” of muck and rust in the bottom of the block and the cooling passages.
I popped the plugs and have been washing out the cooling passages.
I had oil on the top of some intake valves and I could see oil weeping down the stem on the exhaust valves as well. Heads had seals but not guides replace when the motor was rebuilt by the previous owner per the work order.
Scat cast 383 crank
Stock style rods
Kb silv-o-lite cast pistons 5cc dish
Piston in the hole .020
Thumpr cam 12-600-4 Hyd Flat
Stock 76cc heads
Performer intake
Edelbrock 4160 carb
2200-2800 stall converter.
I’ve been eyeballing the Brodix IK200 heads and some 1.6 rockers. With a 64cc that is going to put me right around 10.6:1 CR with a .040 Head gasket. I could bump up to a .045 or .050 head gasket but don’t want to go that thick. Alternative is 70cc heads but that drops the Cr to 9.75:1.
With 93 gas and thumper cam is 10.6:1 pushing it on the CR?
The car is just a street cruiser but I want to make sure I size everything right and not make the wife mad about the cost.
Scat cast 383 crank
Stock style rods
Stock 76cc heads
Performer intake
Edelbrock 4160 carb
