I've been wanting to buy one of these, and see Summit has them on sale right now. I've got some other parts I need to order too, so thinking now is the right time to buy. I have a couple questions on installation though.
I have not found installation instructions on the web. I did find a video on the Transgo website and downloaded it, but I must not have the proper codec to view it on my computer here at work.
First thing I want to know is, can I install this kit with the trans still in the vehicle? I have read some eBay ads where they say some parts of the kit can be installed under the vehicle, but other parts require tear down of the trans. Can anyone elaborate on this? Is it worthwhile to do a partial install? Could I get the same results just buying the cheaper shift kit vs this reprogram kit?
Second is what other parts do I need to get in order to complete this? I assume I will need a filter/gasket kit and of course a case of trans fluid. Anything else? Any hard parts I should consider replacing?
Third, I plan to buy an aftermarket convertor to replace the stock one. Probably somewhere in the 2800-3200rpm stall range. Should I wait until I have the convertor to install the shift kit? It seems to me that it would be easier to just drag the whole trans out from under the truck and do all the shift kit work on it, slap the new convertor on and then reinstall.
This trans is a '99 model from a 1-ton truck. It is installed in my C10 behind a mild 454. I am using a TCI controller to handle the shifting. Are there any programming changes I will need to make after I install the shift kit?
