Ok, I have changed a bunch of stuff on the 66, and including the body bushings last week. I put the steering column to firewall plate rubber insulator back in today.
Still has a seemingly cyclic vibe in the steering wheel, about three increasing vertical shakes, stops, and goes again. Seems less than wheel speed.
Nearly unchanged in five years. New tires, balanced, new front discs, rotors, spindles, shocks, springs, good control arm bushings. Its aligned, does not wear tires.
Rear has new tires, balanced, new shocks, springs, new bushings, adjustable upper arms. Driveline angles are between 1 1/2 to 2 deg iirc.
Driveshaft was balanced.
New crank and shortblock.
Same wheels, rear brake drums, rear gears, axles, etc. Same balancer, flexplate, converter and th 350. Old ragjoint, and orig manual steering box. Tie rods and ball joints are decent.
Suggestions welcome!
