1 - 11 of 11 Posts
Guys ..... having ignition problems ...........weak spark .......Mallory 6AL with magnetic trigger in dist with mallory stock type coil .........getting progressively worse hard starting and keeping idle clean .........plulled coil wire and found coiltower had oil in it removed coil ...coil definitely leaking oil out the tower .......put a spare MSD blaster coil in car ...no change ......crank engine with key on weak spark when spark plug grounded to block ........where do i check first
I would touch the magnetic pick-up wires together on the box then release them and see how strong the spark looks like at the coil.
Dave
SO if i understand correctly take a paper clip and jump the connector that goes to dist and watch the coil wire jump to the block ....... howe strong is stron g enough
· Super Moderator
cdn
Which distributor ?? If it is an MSD, the forst thing I would do would be to replace the cap and rotor, even if the present ones look like new. I have had a couple of customers lately fix similar problems by replacing the caps and rotors on MSD distributors, even though they could see nothing wrong with the old ones.
If you're using the stock ignition wiring, it probably still has the ballast resistor wire in the circuit.
Try running a LARGE (#12 at least, preferably #10) wire from the IGN point in the fusebox, straight to the ignition system. Use those big thick heavy "beast" connectors, not the regular little weenie ones.
cdn
Hey Bill ..........small body GM dist with Dave Ray magnetic trigger igniton module( actuall a ford unit I think ) ...with MSD cap .......and that cap has never fit tight since day one ..............will do Thanks
What would cause the coil to leak ..I realize an old coil coud do that but never had an aftermarket one do that
No the ballast wire is not used ..new harness .ran fine last season
· Banned
Make sure with the key off you have less than 0.4ohms resistance from the negative side of the system to the head where the spark plugs groung out {in the threads}, on mine its less but i have a main ground wire going to each head to insure the head doesnt get isolated from ground with thread sealant on the head bolts and head gasket
Also, make sure all grounds have less than .4ohms resistance from negative {at battery is fine} to the ground wire for box
Make sure you dont have any voltage drop of more than .4 also
1 - 11 of 11 Posts
